need help in code for pic24f controller
malhi
Newbie level 6
i have made a code for interfacing LCD with pic24fj128ga010
but i do not have output as a string. i am getting it as numericals which is changing randomly...
i am not able to solve it...........please have i look :!:
#include "p24FJ128GA010.h"
#include "lcd.h"
#include "delay.h"
For Explorer 16 board, here are the data and control signal definitions
RS -> RB15
E -> RD4
RW -> RD5
DATA -> RE0 - RE7
// Control signal data pins
#define RW LATDbits.LATD5 // LCD R/W signal
#define RS LATBbits.LATB15 // LCD RS signal
#define E LATDbits.LATD4 // LCD E signal
//#define E LATFbits.LATF1 // LCD E signal
// Control signal pin direction
#define RW_TRIS TRISDbits.TRISD5
#define RS_TRIS TRISBbits.TRISB15
#define E_TRIS TRISDbits.TRISD4
//#define E_TRIS TRISFbits.TRISF1
// Data signals and pin direction
#define DATA LATE // Port for LCD data
#define DATAPORT PORTE
#define TRISDATA TRISE // I/O setup for data Port
unsigned int temp_count;
const char mytext[] = " PIC24F Demo ";
const char mytext1[] = "hi how r u?";
/***** LCD SUBROUTINE *****/
void Init_LCD( void ) // initialize LCD display
// 15mS delay after Vdd reaches nnVdc before proceeding with LCD initialization
// not always required and is based on system Vdd rise rate
Delay(Delay_15mS_Cnt); // 15ms delay
/* set initial states for the data and control pins */
LATE &= 0xFF0F;
RW = 0; // R/W state set low
RS = 0; // RS state set low
E = 0; // E state set low
/* set data and control pins to outputs */
TRISE &= 0xFF00;
RW_TRIS = 0; // RW pin set as output
RS_TRIS = 0; // RS pin set as output
E_TRIS = 0; // E pin set as output
/* 1st LCD initialization sequence */
DATA &= 0xFF0F;
// DATA |= 0x0038;
DATA |= 0x0000;
E = 1;
Nop();
Nop();
Nop();
E = 0; // toggle E signal
Delay(Delay_5mS_Cnt); // 5ms delay
DATA &= 0xFF0F;
DATA |= 0x0020;
E = 1;
Nop();
Nop();
Nop();
void lcd_cmd( char cmd ) // subroutiune for lcd commands
// TRISD &= 0xFF00; // ensure RD0 - RD7 are outputs
DATA &= 0xFF0F; // prepare RD0 - RD7
DATA |= cmd; // command byte to lcd
RW = 0; // ensure RW is 0
RS = 0;
E = 1; // toggle E line
Nop();
Nop();
Nop();
E = 0;
cmd=cmd<<4;
RS = 0;
Nop();
Nop();
Nop();
E = 0;
void lcd_data( char data ) // subroutine for lcd data
RS = 1; // assert register select to 1
DATA |= data; // data byte to lcd
E = 1;
Nop();
Nop();
Nop();
RS = 0; // negate register select to 0
Delay_Us( Delay200uS_count ); // 200uS delay
data=data<<4;
E = 1;
Nop();
Nop();
Nop();
int main(void)
/* Initialize LCD Display */
Init_LCD();
/* Welcome message */
home_clr();
puts_lcd( (char*) &mytext[0], sizeof(mytext) -1 );
line_2();
puts_lcd( (char*) &mytext1[0], sizeof(mytext1) -1 );
void puts_lcd( unsigned char *data, unsigned char count )
while (1)
lcd_data( *data++ );
count --;
void Delay( unsigned int delay_count )
temp_count = delay_count +1;
asm volatile("outer: dec _temp_count");
asm volatile("cp0 _temp_count");
asm volatile("bra z, done");
asm ("repeat #1500" );
// asm volatile("do #3200, inner" );
asm volatile("nop");
// asm volatile("inner: nop");
asm volatile("bra outer");
asm volatile("done:");
void Delay_Us( unsigned int delayUs_count )
temp_count = delayUs_count +1;
asm volatile("outer1: dec _temp_count");
asm volatile("bra z, done1");
asm ("repeat #3200" );
// asm volatile("do #1500, inner1" );
// asm volatile("inner1: nop");
asm volatile("bra outer1");
asm volatile("done1:");
:cry::cry::cry:
