need help in a module that detects wireless RF switches
orchidboy
Newbie level 2
UK
Wireless RF Switches
I would like to build a module that detects a number of separate wireless switches located across a room (maximum 16) either using RF, Bluetooth or some other transmission method that does not require a “point to point” view (ie Infrared) the maximum transmission distance is 30 ft.
The only Output I need from the transmitter is a simple on/off switch; with a corresponding LED to be lit on the Receiver unit i.e. transmitter switch 4 will light the LED 4 on the receiver...
Can anyone suggest the best way of approaching this??... is there a module or circuit out there that will allow me to do this??
Thanking you in advance for all of your help.
Regards
Ajay Sood
GSM Man
Banned
New Jersey, USA
Re: Wireless RF Switches
This is exactly the type of application ZigBee was developed for. Microchip has a nice product offering including hardware, a Free Zigbee stack and several demo/development boards. You should check out their "Zigbee Design Center" at: **broken link removed**
orchidboy
Newbie level 2
UK
Hi GSM Man,
Thank you for your post... I was not aware of Zigbee before this and this is definitely something I will investigate further...
My only major concern right now is the cost of the individual components, is there a cheaper alternative?
My plan was to link the Receiving unit to Arduino, so that when a switch is triggered a suitable "program/subroutine" is run, i noticed that the Zigbee stack has it's own PIC components.... can you just purchase the transmit/receive modules and link them to Arduinio?? or something similar??
Thanks again for your help, it is most appreciated.
Regards
Ajay
