Need help identifying transistor(mosfet?)
zanor
Member level 4
Norway
transistor mosfet
I am repairing a car audio amplifier and found two bad output transistors. But the only thing that is written on them is C4466.
Does anyone know what specs theese are? Or could find a replacement on futurlec.com?
Thanks!
Stian Pettersen
identifying mosfet
Look for 2sc4466.
Transistor 2SC5149 is designed for different purpose.I look around two different
datasheets for 2SC4466 from SANYO and SANKEN.From futurelec.com You may
use 2SC3281, but may have problems. First necessity isolate collector from
heatsink.
Good luck from Riga!
identifying bad mosfet
www.alldatasheet.com might may help u
Thanks!
Stian Pettersen
transistor mosfet specs
ok
Thanks!
Stian Pettersen
Industry Number : C4466(TRANS)
NTE Device Number: NTE390
T-NPN,SI-POWER AMP,TO-218
Thanks!
Stian Pettersen
That is 2SC4466, please note that Japanese transistors are always omitted "2S" in their number codes on packages. It is not MOSFET, but npn BJT.
You can get the datasheet from either following link:
https://www.alldatasheet.com/datasheet-pdf/pdf/38005/SANKEN/2SC4466.html
Knowing well about it, you can easily find out the replacement.
Good luck.
nguyennam
just write the number of transistor and the key word transistor in www.google.com
if didnt work search "datasheet" on google therell be thousands of datasheet searching engins available.
