need help identifying lcd module on circuit board
robismyname
Full Member level 6
Central Florida
Can anyone help me identify the lcd in terms of a part number. This lcd module is located on my rainbird esp-6tm controller. The lcd went partially bad and Im trying to replace the part instead of buying a whole new controller box. Pictures are provided.
18 pins on each side. approx. (1 5/8")L x (7/8")W
LCDs are recognised by the segments they glow.
If you want to find a similar LCD you need to have segment this LCD used to glow. All segments.
This you can draw by hand also, just try to remember where which 7 segment / idetifiers / icons used to glow??
If you can post that someone can recognize the similar available LCD.
If you are lucky see below LCD if there is any printed inscription. for that you need to de-solder LCD
