Guren2
Newbie level 1
DONT KNOW WHICH MICROCONTROLLER TO USE!
Hi im new here and the sole purpose to join this was to get some answers i cant find anywhere! :O Im hoping some of you smart people stumble across this and help me out soon...
So im making an AIR to FUEL RATIO CONTROL SYSTEM for IC ENGINES...what im gonna ask has nothing related to engines so dont worry...
Im taking one input from a fan, that rotates when high pressure air passes through it, in VOLTS(.as the speed of fan increases so does the voltage produced), and im still working on the second input (it would probably be in Volts but it could also be a shaft encoder so in that case it could be 'theta'...)
but anyway, i dont know much about programming...have done some C++ in freshman year but thats it..I need a microconttroller which can
NOW i dont know what to look for in an mcu or how to choose a microcontroller..like how much memory it should have or how many input output ports or if it should have a USB or SERIAL port etc...
once i have it i have a friend who could program it but i need to GET one first! im really desperate....i really need some proffessional advice and hopefully someone who could assist an electronics newbie to make her way through this...
THANKS!
- read the inputs
- manipulate them by mathematical formulation into useful data ( that involves a lot of math functions)
- check and see if the input data matches the required input (or the AFR input)
- command an actuator (on output) to change the applied voltage (or speed of fan etc) IF the input is not matching the required input
THANKS!
