NEED HELP FOR PROJECT
rohit yuvaraj chaudhari
Newbie level 3
mumbai
hellooooo
we r making a project on LCD THERMOMETER using LM35.
we r using ic ATMEGA 8.
PLZ HELP ME ABOUT C PROGRAMING FOR THIS PROJECT.
PLZ SEND ME PROGRAM IF U KNOW.
thank u very much sir..
now can u plz tell me in which software should i run the AVR's program????
plz help me...
i need it....
You will need a compiler. That code used AVR-GCC as a compiler.
Then you will need a download software and a downloader circuit to download the avr-gcc output to your chip.
Amr Ali
hello now im trying to make dis project using 89S51 n ADC0808 AND LM35 sensor.
so plz help me C program for this project 2 display temperature on LCD.
giv program which i can use in micro vision keil software.
plz plz give me this program as early as posible....
i need it urgently.
plzzzzzzzzzzzzzz
if possible plz giv me hardware diagram also........
plzzzzzzzzzzzzzzz
add this sftware to keil, compile. You will get errors, fix them. Thats the fastest way.
Amr
provide me program plzzzzzzzz for lcd thermometer using lm35 n microcontroller 89s51.......
plzzzzzzzzz i need it.....
gv program in c language which i can use in keil........
plzzzzzzzzz
