ben8118
Junior Member level 1
- Joined
- Feb 12, 2010
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kuala Lumpur
- Activity points
- 1,419
Dear all,
I'm designing a wireless system using 315Mhz frequency.
The antenna of the system need to be inside the casing. The system is power by 2 x AAA battery (3.3v).
I use 12v step up regulator to increase the 315mHz module strength. If using 3.3v, the signal strength is between -48dbm to -45dbm.
If using 12v, the signal strength is up to -40dbm to -38dbm.
My problem is i need to achieve at lease -25dbm, because I need to achieve 3 floor distance.
Please give advice. Thanks.
