ii didnt have the schematic but would be plz till what is ur tv problem i read thats this tv sets have problems happen in volume and in vertical and colour system so what is ur problem maybe i can help you
pin 2 of the vertical IC LA7838 had a dry solder joint this made the TV loose vertical sync ocassionally and then finally it went completely dead where all I would get is a horizontal line. I resoldered LA7838 and it works fine now, but I wanted to have a copy of the schematic for future reference just in case something else goes wrong
https://www.servicemanuals.net has this service manual available for immediate download. Also, use the following coupon for 20% off. The coupon can be used over and over and is good forever.
Simply enter "DODGERS" at checkout, then you must click "APPLY" to get 20 percent off any download order.
