need help BUZZER 220v with alarm clock
modi_81
Junior Member level 1
jenin-palestine
buzzer 220v
how can i connect BUZZEER 220V with alarm clock that turn on battery AA 1.5v
please
when the alarm clock ringing(small motor switch on) must the BUZZER 220V switch on
IanP
Advanced Member level 5
West Coast
220v alarm clock
Because of the low voltage (1.5V) your options are very limited ..
Maybe you can use an optocoupler, for example the MOC3021 - with the emitter's input forward voltage of just ≈1.2V, and to drive a buzzer of 220Vac use a triac .. see picture below ..
Regards,
IanP
sinip
Full Member level 4
Republika Srpska
please
Or you can use appropriate low voltage (reed) relay instead of motor to switch on the buzzer.
