need help-array vs vector
fanwel
Full Member level 3
Dear all,
I have 4x4 matrix and I want to read this matrix row by row on each clock cycle. For example, row1 is read in cycle1, row2 is read in cycle2 and so on. I write the code using array but it cannot read the matrix row by row as I want.
Can anyone give me idea how to write this code, please? Many thanks
it depends. If you have an array of arrays, its going to be much easier:
type row_t is array(0 to 3) of std_logic_vector(7 downto 0);
  type matrix_t is array(0 to 3) of row_t;
  signal matrix   : matrix_t;
  signal temp_row : row_t;
  signal count    : unsigned(1 downto 0) := "00";
begin
  process(clk)
  begin
    if rising_edge(clk) then
      temp_row <= matrix( to_integer(count) );
      count    <= count + 1;
    end if;
  end process;
If you're using a 2d, matrix type, things get a little more complicated as you have to use a function to extract the row, but it should generate the same logic.
  type matrix_t is array(0 to 3, 0 to 3) of std_logic_vector(7 downto 0);;
  function extract_row( m : matrix_t; row : integer) return row_t is
    variable ret : row_t;
  begin
    for i in row_t'range loop
      ret(i)  := m(row, i);
    end loop;
    return ret;
  end function;
begin
  process(clk)
  begin
      temp_row <= extract_row( matrix, to_integer(count) );
      count    <= count + 1;
    end if;
  end process;
NB: Matrix could be an input to your entity.
Dear TrickyDicky,
This is my code that I write referring to your code above:
library ieee;
use ieee.std_logic_1164.all;
entity TM is
port(input: in std_logic_vector (0 to 3);
clk: in std_logic);
end TM;
architecture arch of TM is
signal count : unsigned (1 downto 0) := "00";
begin
process(clk)
begin
count <= count + 1;
end if;
end process;
end arch;
But, this error occurs:
Error (10482): VHDL error at TM.vhd(14): object "unsigned" is used but not declared.
Thanks for reply.
add this line to the top of the code,
use ieee.numeric_std.all;
Reactions: fanwel
    fanwel
Dear vipinlal,
Thanks, its look okay now.
---------- Post added at 05:03 ---------- Previous post was at 04:30 ----------
Dear vipinlal,
By the way, can you explain the function of the line: use ieee.numeric_std.all;
---------- Post added at 05:38 ---------- Previous post was at 05:03 ----------
Dear all:
This is my testbench code:
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity TM_tb is
end;
architecture bench of TM_tb is
component TM
clk: in std_logic);
end component;
signal input: std_logic_vector (0 to 3);
signal clk: std_logic;
constant clock_period: time := 10 ns;
signal stop_the_clock: boolean;
begin
uut: TM port map ( input => input,
clk => clk );
stimulus: process
begin
input <= "0100",
"0101",
"1110";
wait for 50ns;
stop_the_clock <= true;
wait;
end process;
clocking: process
begin
while not stop_the_clock loop
clk <= '1', '0' after clock_period / 2;
wait for clock_period;
end loop;
wait;
end process;
end;
When I compile this code in Quartus its okay. But then, when I compile it in ModelSim this error occurs:
**Error: H:/altera/TM5_test/TM_tb.vhd(30): Delay in signal assignment must be ascending.
Where I am wrong?Anyone help me please..
numeric_std is a library that contains the signed and unsigned types, and all the arithmetic functions that go along with them.
The error you are getting is because you're trying to assing 3 sequential inputs all at once without a delay beteen them. You probably want a delay between each one:
stimulus: process
begin
  input <= "0100";
  wait for 50 ns;
  input <= "0101";
  wait for 50 ns;
  input <= "1110";
  wait for 50ns;
Reactions: fanwel
    fanwel
Dear TrickyDicky,
Thanks for your helps.
