Hi folks,
I purchased a UPS that did not come with the needed wiring harness so I thought I would build it. The problem is I do not know the fuse I need for the jumper. The battery pack is made of four 12 volt 7 amp batteries. It is wired to make a 24V 14amp pack. It is wired exactly as in the picture below. I need to build the jumpers with the fuse. What fuse should I use?
