Need for generated clock
pradeeppiskala
Member level 1
bangalore
What is the need for creating generated clocks?
1) It can be used to set false path between different clock paths. If we have a functional and test clock coming to MUX. we can set false path between them.
2) To optimize timing critical paths.
Are there other reasons for using generated clock?
Why do we use divide by number when defining a generated clock?
For example, to emulate block (black-box), that multiplies/divides an input frequency.
Generated clocks are used to create clocks within the design , so as to reduce extra pll or clock generators which may be needed to drive the clocks without the use of clock dividers.
It is for tool to understand the structure of clocks.
Clocks are generated in DC to specify input and output port delays...
ex: If we take an input it might have delay coming from the source. So, it is used to specify the estimated time taken to arrive at your module.
hope this helped...
