need explanation of working of ic 7HCT245
npriya
india
74hct245 project io
can you explain the working of ic 7HCT245
aanand_44
Junior Member level 2
India
7hct245 datasheet
I think this is a one of the octal bus transceiver. This is designed for asynchronous two-way communication between data buses. The control-function implementation
minimizes external timing requirements. If its correct means give me your project details I will give more information about your project and the IC.
Regards,
Anand.A
pranam77
Advanced Member level 5
INDIA
Re: project
Hope it is 74HCT245. You are sitting in front of a pile up of information on the net. You just need to google it. Any ways instead asking such silly questions you may have a look at the datasheet yourself. Good luck
vigneshwara_s
Member level 1
Chennai
Re: project
The IC 74HCT 245 is the Bidirectional Buffer IC and it is having 8 + 8 i/o pins named A0 -A7 and B0 - B7 .
When the OE poin is Set High , There will be No Data transfers in the 74HCT245 and the IO lines from A0-A7 and B0 - B7 will be in High impedence state ..
when OE is Set to low ,
a) when DIR Pin Set to low , the Dats available at the Input B0-B7 will be available at A0-A7
b) when DIR Pin Set to High , the Data available at the Input A0-A7 will be available at B0-B7
This is the operation of 74HCT245.
These things you can find out in the Datasheets itself in the Function table or Truth table section of the datasheet.
sn_burki
Full Member level 5
Pakistan
Re: project
Octal 3-State Noninverting Bus Transceiver With LSTTL-Compatible Inputs
The 74HCT245 is identical in pinout to LS245. The device has TTL-Compatible Inputs. The HCT245 is a 3-state noninverting transceiver that is used for 2-way asynchronous Communication between data buses. The device has an active-low Output Enable pin, which is used to place the I/O ports into high-impedance states. The Direction control determines whether data flows from A to B or from B to A. By ON Semiconductor
