Need explanation of the circuit
adnan012
Advanced Member level 1
hi,
I need explanation of the attached circuit schematic. What is the purpose of D1, D2 and T1. This circuit is used in electric fishing. i generated high voltage pulse at 30 to 100Hz rate with variable duty cycle.
Fish murderer! That is probably the least Eco-friendly device I've ever seen.
D1 and D2 are to conduct a high voltage, high current pulse to T1 which steps it up approximately three times higher in voltage. They are SCRs, a kind of diode that needs switching on and stays on until the voltage across it is removed. When triggered, D1 dumps the high voltge into T1, then after a short period, D2 reverses the voltage across D1 to stop it conducting again. It's called "commutation". Keep fingers WELL AWAY from that thing, it can easily kill people as well as fish.
Brian.
thanks for reply.
i need more explanation for the following.
"When triggered, D1 dumps the high voltage into T1, then after a short period, D2 reverses the voltage across D1 to stop it conducting again. It's called "commutation"."
what is the function of secondary side of T1?
High DC Voltage is present at point B of D1.
When D1 is turned on Dc voltage are applied to the transformer T1 and are available to the load point (a small circle). How voltages are amplified at this point? is there any flyback/ back emf action?
What happens at the secondary side during D1 turn on time?
How D2 reverses the voltage across D1 to stop it conducting again?
20A at 1.2KV!! you are more likely to kill yourself than the fish. I disapprove of the use of this circuit.
This is why I didn't expand my earlier reply.
Either Adnan012 understands the circuit or they shouldn't be using it. In this case, a lack of knowledge could have disastrous consequences, including loss of life of more than one person.
Adnan012, please don't use it for your own sake. It is VERY unsafe and if you have one that has failed, it should be returned for professional repair. Personally, I think this kind of device should be banned Worldwide.
Thread now closed.
Brian.
