afesheir
Member level 1
dear everybody ..
I am using samsung S6B0108 GLCD .. I got its datasheet but I still have some confusion ..
for the instruction: Write Display Data, I have to apply 0 to RST pin, 1 to R/W, and 8-bit data to DB7->DB0 .. are these 8-bit ASCI code or what ..? or its internal chips have standard characters ..?? if so, then how can I draw images and shapes on it ??
there is another instruction called "Read Display Data" .. how can i make use of it .. it retrieves data from the display RAM ..????
the last point, each instruction is composed of 10-bits word .. well, how much time delay must present between different instructions ..??
I read the datasheet and found nothing .. this is the datasheet
