Need example - bias current in CMOS integrated circuit
kickbeer
Full Member level 3
bias current
can someone show me the example of calculation to determine bias current in CMOS integrated circuit?
bias current
your question is beyond vague... what circuit in particular? opamp? lna? oscillator? SCL logic? what are your requirements and constraints? what process are you using? etc..
Re: bias current
hi oermens,
the circuit is comparator.See the the circuit in the attachment. How to determine the vbias? the process technology is 0.35um with 3.3 V supply voltage.
Re: bias current
hello oermens,
sorry last time i forgot to attach the comparator diagram. you can see again from the previous message
Re: bias current
Id (M8 ) = Id(M9a) + Id(M9b)
so vbias = Vgs value which gives Id(M8 ) considering the effects of Vds8
Practically u can find this Vgs value by plotting V-I curve for M8
you can refer to any books on Analog CMOS design.
Hope this helps.
Thanks,
    kickbeer
Re: bias current
Hope this helps.
Thanks,
thx blackuni,
small question. Id(M9a) + Id(M9b) depends on Id(M8). Am i right? if we change Vbias, that means, we change Id of M9. Please correct me if necessary.
