i am a beginner. pls send me the embedded-c coding for reading digital output of a IR sensor in 8051 microcontroller for its 30 I/o pins!( 30 ir sensors are connected to its 30 IO pins) I am using Keil compiler!
Do not ask people to spoon feed you by looking for codes. You can tell your inputs and outputs and ask for help in the logic or if you are experiencing some problems. This is not the Engineers way.
