CPUNeck
Newbie level 3
Is there a way to create an electromagnet surrounding either a rubber hose, or steel tube in such a way as not to get hot, but still deliver a strong magnetic field? This unit would be powered by 12v DC on an automobile.
Initially I thought I would just create a winding around a portion of steel tubing, but then discovered the heat imparted to that tube may be a problem. I'm not trying to heat the fluid at all. Thanks.
