Need current source 0-20mA schematic
mrcube_ns
Advanced Member level 1
Europe
current source schematic
Hello friends,
I tried to search for schematic on this forum but I wasn't find any schematic i got over 7000 matches.
Can someone post me some, good one, schematic for current source (or link to it), (I want to use precise (10 or more round) potentiometer to change current), with transistors or OP amp or you tell me.
Thank you in advance.
Mr.Cube
constant current source schematic
One possible option is to use an opamp in voltage-to-current configuration where the output current I = Vin/Rsense .. drawback: sinking current ..
However, instead of trying to reinvent a wheel why not to use off-the-shelf solution ..
Its name is XTR110 and your multiturn potentiometer can be connected between 5V reference-ground and pin 5 (in 0-5V to 0-20mA configuration) ..
https://focus.ti.com/docs/prod/folders/print/xtr110.html
( In fact you can copy its internal configuration and build the whole circuit using standard opamps) ..
Regards,
IanP
    mrcube_ns
