abhay kulkarni
Member level 3
I need service manual or circuit diagram for Genius make inverter.
capacity 800VA.
pl.
capacity 800VA.
pl.
Usdually the transformer is a ac voltage sensing one. If you found it to be open, give it to a re-winder who will rewind the primary side as per the old specs by counting the old coil counts and you'll get the same output as before as the secondary need not be replaced unless the former is burnt off or a short persists in it.my inverter remains "on" even though mains supply is present.
I checked & found that there is a small transformer inside, Its primary coil found "open". I want details of that transformer and circuit surrounding it.
