Need CCP module basic in microC
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
CCP, Capture/Compare/PWM module of PIC microcontrollers. I need the basic thing about compare module. How can I get a stable frequency using this module?
I'm trying... but need help. Better if you can give me an example code in microC.
Thanks
I was trying with this:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
#define   Clock1   RC5_bit
void interrupt()
    if(CCP1IF_bit)
       CCP1IF_bit = 0;// clear flag
       Clock1 = 0;
    if(TMR2IF_bit)
      Clock1 = 1;
      TMR2IF_bit = 0;//clear flag
} // ISR...
void PORT_Init(void)
   TRISA = 0xFF; // PORTA input
   TRISB = 0b00000001; // PORTB output except RB0 & RB1
   PORTB = 0x00; // all zero
   TRISC = 0b00001000; // PORTC output
   PORTC = 0x00; // all zero
void main()
   PORT_Init(void);
   // Timer2 settings for 7ms interrupt
   T2CON = 0x36;
   PR2 = 223; // 10 ms time
   TMR2IE_bit = 1;
   INTCON = 0xC0;
   // compare module settings...
   CCP1CON = 0b00001011;// trigger special event
   CCP1IE_bit = 1;
   CCPR1L = 0x1B;
   CCPR1H = 0xCF;
   //timer 1 settings...
   T1CON = 0x01;
   TMR1IF_bit = 0;
   TMR1H = 0xCF;//10ms timer
   TMR1L = 0x2B;
   while(1)
   }  // while
}// void main
Output is: sdfsfadf.png
Can you tell me what the wrong I'm doing here?
I need to generate 50Hz PWM push-pull signal for inverter. And also need to control a TRIAC to control the charging section.... So 3 pulses need to be generated.
Simple PWM will not work.
