need bascom sample code to tx over RF (AVR)
allomani
cairo
Hello,
i want a sample code to use atmega8535 to transfer over 433Mhz Rf
i tried UART to transfer between two microcontrollers and it works , but with RF it show nothing...
nandhu015
Advanced Member level 5
India
you need to do manchester coding and decoding to get proper reception
Nandhu
Reactions: joco10
    joco10
allomani
cairo
can you explain more please and if you have any BASCOM example code
anandpv2009
Advanced Member level 1
allomani said:
Hello,
Ya...
try Manchester coding or ICs like HT12D, HT12E. But they are not good for data transmission. Only for remote control like applications.
Good Luck.
allomani
cairo
actually i tried the HT12D, HT12E but they didnt work with me with control also , i used 10kohm resistors for OSC , are they make a difference ? and how i connect them for data ? should i use 1 data pin only and use UART or there are another connections needed ?
and about another wireless solutions , which better for data ?
nandhu015
India
Use 51k and 1M resistor's. If you dont get 51K then series 47K + 3K9 resistors.
It is working. I checked it personally.
Nandhu
