Need AVR programmer to download hex file to ATtiny2313
computer eng.
Junior Member level 2
Hello everyone ..
I have project working on AVR and I need to buy a programmer to download hex file .. From where can I get one and there is any website to order one .. I'm use ATtiny2313 ..
Please I need your help..
madhub63
Junior Member level 1
avr programer india
Go to
WWW.IKALOGIC.COM and go to microcontroller section
u can build the programmer for almost all avr microcontrollers.
madhub63
avr programmer in india
No modification required u go ahead with that one.
pranam77
Advanced Member level 5
INDIA
avr microcontrollers toronto
senthilkumar said:
is this pic or AVR?
Keeprog is an AVR programmer. You can have more info from www.united77.com/keeprog.htm
PIC Cruizer from United 7 supports the PIC micros. You can get the info from thier website mentioned above...Good luck
pranam77
INDIA
making your own isp for avr programming
The black connector is an ISP connector which connects to the chip which is on the target board. The pin connnections are given on the same page.
blueroomelectronics
Toronto, Canada
kmitl.avr
When using a parallel port programmer make sure your OS can talk to it. Check for XP & Vista drivers beforehand.
ibrahim03
Full Member level 1
Re: AVR programmer
You can also try making your own programmer. All you need is a DB-25 parallel port connector and some other basic components. You can find alot of circuit diagrams for making your own programmer. Just search Goolgle!
I made my own ISP, parallel port programmer, a couple of years back. Cost me almost nothing compared to the price of these programmers and kits in the market. I used the Ponyprog software to burn my hex files into the uC. Used it to program my ATMEGA 32.
eehero
Full Member level 3
Libya
AVR programmer
umm guys our friend needs to program his tiny2313, easy way is to use pony programmer, build it urself it is so easy to build and use, here is the link:
