Need an FPGA board for realizing (S)ATA over Ethernet
staraimm
Full Member level 2
Full Member level 2
I want to realize the (S)ATA over Ethernet. Can anybody suggest me a FPGA board to realize that?
ethernet <-> FPGA <-> (S)ATA
Thanks a lot.
Re: Need a FPGA board.
Did anybody do the design of the (S)ATA over Ethernet? Any suggestion is appreciated.
You can use MAX Plus 2 FPGA board.
How about a Virtex 5 ?
Commonly, the Virtex IV and V are very expensive. Do anybody know a cheap FPGA board?
Need a FPGA board.
i think max plus 2 is enough.. virtex is usually used in dsp... using virtex is an overkill
reyge, I need a FPGA board, not only the FPGA chip. Can you give me a suggestion? Thanks a lot for your reply.
Need a FPGA board.
If you search in xilinx website you will get Ethernet supported boards. So, you can use those boards for your design.
this is a low cost board and supports Ethernet from xilinx
**broken link removed**)and
    staraimm
Thanks a lot for everyone's reply. I think I have to search the board on the xilinx website.
