Need Altium Designer help: Net has no driving source
K.Srikanthreddy
Junior Member level 2
I am getting "Net has no driving source warning" whether it is ignorable or not.
Please help me.
PCBcomponentlibraries
Cheshire, UK
This error has to do with the pin allocations, if you double click a part and unlock its pins, then double click the pin that is causing the error you will be able to see the electrical type. This should be set corectly to suit your component / design. Most of the time its a non error, but it depends on your design.
abaz
Member level 2
Berkeley, Australia
Another anoying thing that causes it is placing terminating resistors in line with a pin thats set up as an output. The net from the terminating resistor to the input gets flagged as not having a driving source
