inequitude
Newbie level 1
Hi guys- I have a question which I hope one of you in this forum can help me with.
I'm got my artistic hat on and am playing around with a sheet of thermochromic ink which I want to lay on the front of a canvas.
Behind the thermochromic ink I want to lay a pattern using some heat conducting wire which will attach to a 9v battery behind the canvas.
The idea is that when the battery is connected, the wire heats and activates the thermochromic ink, thus revealing in all it's splendor the pattern I have made with the wire behind it.
The tricky part is that I want this heat/battery to conduct through the wire as a pulse, ideally approx every 60 seconds for several seconds.
Is it possible? and what electronics do I need to get to make this happen? If someone could explain to me in layman's a) what i need to purchase, and b) the process of assembly, I would be most grateful.
...ideally if I could buy this little pulse/delay mechanism thing already made up from somewhere it would be fantastic, as I dont have the suspected requisite equipment.
Please advise
Cheers,
Chris.
Please advise
Cheers,
Chris.
