I need a help to find a Transceiver module. which need to have a transmit range even 1Km or 2Km. Or else can I get this much of range by using an antenna ? if so which type of antenna is better ?
And also need to support multiple channels(8 channels are enough).
better if it has a SPI interface.but UART or USB also ok.
You may get better range with YAGI antenna's on both side. TX and RX. For Increasing power of the transmission, you need a valid license in India...Cheers
U can use Zigbee wireless module from Maxstream
Data rate 250Kbps, Frequency is 2.4GHZ and select the module which will suit ur requirement.
Interface is UART
Good luck with the range. Also if you are transmitting continuous packets back and forth you will notice packat loss using Zigbee from digi. Zigbee from Tarang has another issue. If you are sending packets more than 32 bytes, some byte are lost from the packet. So be careful using both of them.
