Need 14 bit DAC that takes parallel input/output 0-10V
fawad_hd97
Junior Member level 3
14 bit DAC
I need a 14 bit DAC that takes Parallel input and outputs a voltage from 0V to 10V.
PLz can u help me out
Re: 14 bit DAC
Use one of the dac's from one of the many companies that make them (e.g., Analog Devices). You don't have to use a 14-bit dac; you can always use one with higher resolution. For example, you can use a 16-bit dac by connecting the dac's two least significant bits to logic 0 and connect your 14-bit data bus to the dac's 14 most significant bits, thus turning it into what is effectively a 14-bit dac.
Re: 14 bit DAC
Most DAC output is current, also what speed do you need?
However you can use DAC904 from TI
Re: 14 bit DAC
Another couple that are voltage output, 14-bit:
MX7841 - **broken link removed**
MX7538 - **broken link removed**
FoxyRick.
    fawad_hd97
