nec remotr cantrol interface with 8051
arun_9998
Banned
india
hey all guyes
can any one help me to nec remote interface to 8051 in c
i tired but i can't interface
please help me
i wrote some code
cpu FQ 12MHz
when event occur by pressing remote key i start interrupt 0(P3^2) isr
isr_()interrupr 0
EX0=0;
TR0=1;
while(ir pin);
TR0=0;
compare TH0>>8|TL0 to 9000 count
after this
TH0=0
TL0=0
TR0=1
while(!ir pin)
TR0=0
compare TH0>>8|TL0 to 4500 count
please help me i cant read lead code i captuer event on P3^2
Thanks
ard
Full Member level 5
Mumbai, India
Hi Arun,
I have never used the 8051 nor 'C'. I generally use PICs with PBP, but I DO have some experience with decoding NEC signals, so here are a few suggestions.
An NEC signal, after the preamble, consist of 32 pulses. The first 8 are the Device ID, next 8 are the complement of Device ID. You can safely ignore these as for a given remote these are the same for all buttons. The next 8 bytes are the function. These are the ones which would be unique to each button you press. The last 8 are complements of the function, so you can ignore these too, unless you need error checking.
Now for the actual decoding; just monitor the *spaces* between the pulses; dont worry about the pulse widths, they would be the same. Assign a '1' for a wider pulse width and a '0' for a short one. Inject these bits into a byte by shifting every bit you read. At the end, you should have a 8 bit number that is unique to your key press.
Look up SB-Projects: IR remote control: NEC protocol for more specifics.
Regards,
Anand Dhuru
arun_9998
Banned
india
ok ! but i cant read lead code please post me any hint
thanks
g_shyam1682
Full Member level 4
Udaipur-Rajshan-India
Hi friend
I have attached some material below.
I have already write successful program for NEC protocol from that maretial.
Hope this is help you.
Shyam
India
  • NEC Protocol.rar
arun_9998
Banned
india
ok! can you share with me your code
thanks.
Hi friend
Shyam
India
