er.akhilkumar
Full Member level 2
Compilation exits with the following error when testbench top i.e tb_top_asic.sv is compiled after the compilation of testcase which is a class named ac_test and has been instantiated in tb_top_asic.sv as test_top by following string:
ac_test test_top;
ncvlog: *E,NOIPRT (/projects/MC_E_E1/wrk/akumar/trunk/src/tb/tb_top_asic.sv,52|30): Unrecognized declaration 'test_top' could be a spelling mistake [SystemVerilog].
Actually I have compiled both tescase and tb top by using following commands:
ncvlog -messages -CDSlib $WORK_ROOT/ini/cds.ncsim.lib -work work -incdir $WORK_ROOT/src/tb -incdir $WORK_ROOT/src/tb/include -incdir $WORK_ROOT/ovm -sv -define nobanner -use5x $WORK_ROOT/ver/template_000.000/ctrl/sw/ac_test.sv //testcase compilation
ncvlog -messages -CDSlib $WORK_ROOT/ini/cds.ncsim.lib -work work -incdir $WORK_ROOT/src/tb/include -incdir $WORK_ROOT/ovm -LINEDEBUG -sv -define nobanner -use5x $WORK_ROOT/src/tb/tb_top_asic.sv //tb top compilation
Both the files units are created in work library. As per my concern this error is generated because ac_test cannot be used while the compiling tb_top_asic.sv, this all is due to the library funda. But my problem is that we have specified the library name in the compilation command i.e -work work, in which these units will be created but haven't specified the libraries in the command which we want to use while compilation.
Please suggest some solution.
---------- Post added at 00:58 ---------- Previous post was at 00:25 ----------
Can you please tell why the following error is generated:
ncvlog: *E,DLCIRD: Circular dependency encountered for design unit 'tb.tb_top_pkg:verilog_package'
tb_top_pkg.sv includes all models, drivers and testcase class.
ac_test test_top;
