Hello,
I need help with NCO ip tool,vhdl code generated from quartus IP tool,and im trying to add this code in my project. could you please say,what should i put on phi_inc_i?
my fpga cyclone IV.yes i calculated phi_inc_i according to the documentation.The question was about I am correctly defined phi_inc_i in vhdl or I should do it in another way?
The data I found shows the C-IV maxes out at 500MHz on the high end part. It might be possible to do 2 samples/cycle @ 350MHz, 3 samples/cycle @ 233Mhz, or 4 samples/cycle @ 175Mhz.
