NC-Verilog post-simulation problem
sevid
Member level 2
cuvmur
Dear all :
when i simulate my codes with NC-Verilog after synthesizing them with DC,some reference errors appear,the errors is list as follow:
ncelab: *E,CUVMUR: instance of module/UDP 'fdesf1a3' is unresolved
in 'worklib.ar:module'.
ncelab: *E,CUVMUR: instance of module/UDP 'clk1a3' is unresolved
ncelab: *W,CUVWSP (.\simplecpu.v,221|26): 1 port was not connected:
CO
ncelab: *E,CUVMUR: instance of module/UDP 'clk1b6' is unresolved
in 'worklib.dr:module'.
ncelab: *F,MAXERR: maximum error count reached (15).
and in my top file, i have used the system task $sdf_annotate as:
initial
begin
$sdf_annotate("design.sdf",mydesign, ,"design.log");
end
Thanks in advance!
Shurik
Full Member level 3
ncelab: *e,cuvmur
Hi!!
Try
nchelp ncelab CUVMUR
tukken
Member level 2
*e,cuvmur
check if you include your library path
stormwolf
cuvwsp
I think the major reason is the library.
love2read
Member level 2
ncelab: *e,cuvmur: instance
check your library link
sevid
Member level 2
ncelab cuvmur
Thanks for all of you.
But this is my first post-sim with NC-Verilog, pls tell me how to link or include my library.
Thanks in advance!
sevid
xuanzhu
Member level 3
shanghai
ncelab: *e,cuvmur:
if you do the post simulation
you need include your library file in your gate netlist or use a file to list the library file, testbench file and gate netlist. The library file includes all the gate discreption that you refer in your netlist
for example
`include "mylib.v"
module xxx
endmodule
or a list file whose content is like the following
mylib.v
tb_xxx.v
xxx.v
sevid
Member level 2
e,cuvmur
To xuanzhu :
but my library file is a **.db file when i synthesize my design with DC.
you mean that i should switch it to a **.v file,yes or no?but how?
thanks a lot.
sevid
Added after 1 hours 47 minutes:
INCLUDE /path/to/ur/library/file //added in my cds.lib
when i specify my **.db in this way,i get the same error.
it seems like i must translate my **.db into **.lib,or cds.lib?but how?
I really appreciate ur help .
sevid
cfriend
Full Member level 1
include library in verilog
In my opinion, you can get *.v file from the lib dir. for simulation.
xuanzhu
Member level 3
shanghai
ncelab: *w,cuvwsp
to sevid
this verilog library file is provided by your vender, such as tsmc, smic, or umc, etc. It is neither written by you, nor converted by your library db file
sevid
Member level 2
ncverilog nowarn
To all :
What i am doing now is just an experiment,and i only have a **.db library file.
But from someone,i have heard that you can get ur library for post-sim with the help of "library analyzer" which is embedded in VSS,or with the "library compiler" which is embedded in DC.
but i don't know how to get it ,help!
Thanks a lot.
sevid
sevid
Member level 2
ncelab verilog module search order
We can only convert our .lib library files to .db,.hdl,.edif library files with the help of library compiler.
So i cann't translate my .db library file to .v file with it.
Thanks to all of you.
The end of this topic.
sevid
Markchang
Newbie level 1
ncelab udp
I think that you should be add below option
ncelab -access rwc -nowarn CUVWSP
sumit_techkgp
Full Member level 2
xxx sevid xxx
Please include library udp in your simulator file list
Sumit
bossbebes
nc verilog library compiler
And what about the scope in the sdf file.
Do you know what should be this field ?
What does it means?
Thxs
A beginner ....
