My PANASONIC DVD/VCR player blows fuse..
headman333
Member level 5
I have this PANASONIC DVD/VCR player which worked well overtime but then suddenly its fuse in the power supply section blows. I tried to look for any burn inside the unit but I found none, every parts looked OK. But, everytime I replace the fuse, when I plug in the power socket to the outlet it always blows the fuse. I don't have any idea where is the problem on my DVD/VCR player.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
The first thing to look for is a shorted capacitor or shorted diode in the power supply. Not easy to track down.
You need to use a ohmmeter which sends less than 0.6V out its leads, so you don't cause neighboring diode junctions to conduct and give misleading readings.
Is the power supply a switching type? With miniature components? Then it will be hard for you or anyone else to work on.
A technician would probably say "Right off the bat I'll offer to test it with a new power supply. If it solves your problem the charge will be $50. If your power supply is good then I can try to diagnose the problem but my time will cost more than the unit is worth. "
If you feel like doing some hazardous experimenting on your own, try installing a variac to reduce power voltage (or add a light bulb inline). Bypass the fuse with a jumper wire.
Then:
* See how much current the unit draws.
* See if you can feel a component heating up.
* See if you can figure out if any board is drawing overmuch current.
* See if the display works.
* See if the tape drive works.
Etc.
Watch that power draw doesn't go over a few watts, lest you risk ruining the unit or causing a component to explode.
Even if you can track down the section that's faulty, to fix it will not be easy unless you have an identical spare from another Panasonic unit.
DIDAKE
Member level 1
PANASONIC DVD/VCR model ? I have schematics
headman333
Member level 5
Can you send me the schematics?
---------- Post added at 01:36 ---------- Previous post was at 01:34 ----------
the model is LSXK0100.
DIDAKE
Member level 1
¿Lsxk0100 is a internal dvd for cpu ?
Only have schematic for home dvd player
headman333
Member level 5
This the model no. PV-D4732. If you have this can you send or post it here?
DIDAKE
Member level 1
Service ManuaL for you.
Schemes in the content of the file.
Always work with caution.
Regards
  • PV-D4732NASVC.zip
headman333
Member level 5
Thanks much DIDAKE...This is helpful!
Tipu606
Full Member level 3
a blown fuse indicates that bridge rectifier may be shorted or the oscillator transistor may be shorted in SMPS type power supply
