MY LG TV will not turn on (LG 47LC7DF)
flecha2
Newbie level 2
My LG TV would take hours to turn on. The red light would just flicker, but nada. I read where this was most likely due to bad capacitors. I opened the set up and sure enough there were several obvious faulty ones there. I purchased the exact replacement, soldered them…and now my TV will not turn on at all. I checked to make sure that everything was connected, etc. Anyone have an idea what could be causing this? Thanks.
flecha2
Newbie level 2
It was 5 radial electrolytic capacitors in the power supply board.
Tipu606
Full Member level 3
check to see if the set is in standby mode from the remote control
sjohn
Newbie level 1
How do you check for that? Mine does the same thing after turning it off multiple times but I don't have a remote.
sheldonstv
Junior Member level 2
UK
fault may be due to the nvm needing reprogramming
milind.a.kulkarni
Advanced Member level 3
Bangalore
If it is radial capacitor...it will be electrolyte type...I think.....do two thing first check the voltage rating of capacitor that you replaced and present on board and second is check the polarity of the capacitor that you are mounted....so check that any unwanted solder get dropeed on your board on not....
good luck
