Your videos are visible now.
Your mechanism looks like the sort of thing that might have a cam or gear with a notch in it. If it doesn't stop after a cycle, it skips the notch and continues for a second cycle.
The natural question to ask: What makes your motor start a cycle, and what makes it stop?
Measurements are precise with a microswith. It needs to be positioned exactly right, and be pressed just right, in order to work reliably.
Depending on microswitch wiring...at STOP position:
* it can make the motor to free run (open)
* or it can make the motor to break (short circuit)
Maybe in "free run" it passes the notch and starts again..
Klaus
I just recognized that your wuring diagram shows the microswitch NC and NO to be shorted. This makes no sense, it makes the switch useless, because the current is never stopped from flowing, either it runs through NC or NO, one of these paths is always closed.
Try to use NC only.
If it does not work: try to use NO only
Klaus
Try to use NC only.
Klaus
* Does your motor draw so much current that it causes the supply voltage to droop?
* Does you motor create noise (glitches) on the supply rails?
Either of these can cause faults in a control circuit.
I have used NO but again Motor does not stop when micro switch press.
NC didn't work
In your diagram both motors are connected to NO and NC. Did you disconnect one motor , or did you just remove one or the other connectors on microswitch.
NC didn't work
I have changed the microswitch connections only
NC didn't work
I had one another motor which has different connections so I decided to changes its connection to make it exactly the other wine (White motor)
Try to use NC only.
Klaus
I have main board which has motor control circuit and has row and column to control the row and column of the vending machine.
I have made changes in motor in two ways:
A. I have attached an image for circuit diagram
In this design I have some pros and cons
PROS: 1. It stops at its home position after one rotation
2. It detects row and column of the machine
CONS: 1. Sometime it does not stop at its home position or take more than 1 rotation
B. I have attached an image of other diagram
In this design also I have some pros and cons
PROS: 1. It stops perfectly at its home position after one rotation.
CONS: 1. It does not detect ROW
Please suggest What should I follow and what should I made changes in the circuit.
Test with the above option A with the following changes:...
-Connect to NC contacts.
-Remove the 100 microfarad capacitor.
I have removed the capacitor but again facing the same issue.
[video]http://www.nls.net/mp/volks/schem/wiper.htm[/video][video]https://electronics.stackexchange.com/questions/395162/vending-machine-motor-and-switch-circuit[/video]
I see that the pcb on motor in your video is different than one in photo.
