Feb 27, 2009 #1 W wakuhuaco Junior Member level 2 Joined Mar 31, 2008 Messages 21 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,283 Activity points 1,428 mwo 3d layout I can make a 3D model of components in Autocad, and import it into MWO for the layout? Some have a basic guide to creating a layout in MWO? This is my first time in pcb design. Thx!!!
Feb 28, 2009 #2 M Manjunatha_hv Advanced Member level 3 Joined Aug 3, 2005 Messages 810 Helped 241 Reputation 482 Reaction score 126 Trophy points 1,323 Location INDIA Activity points 8,689 Re: MWO layout Hello wakuhuaco, Yes, you can import the Layout from AutoCAD but not in 3D format... AWR MWO accepts AutoCAD DXF, GDSII file formats which may be multi-layered... To do this go to Layout tab => right click on Cell Libraries => select Import DXF library & select the Autocad DXF file... If you see the Geeting Started or User Guide -Chapter 12-Layout section which has some examples on layout drawing in MWO... ---manju---
Feb 28, 2009 #3 W wakuhuaco Junior Member level 2 Joined Mar 31, 2008 Messages 21 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,283 Activity points 1,428 Re: MWO layout Thank you very much Manju
