inductor
Junior Member level 2
Hi
I like to listen to a station 1000 Miles away on 1190KHz at night. I use a tuneable multi turn magnetic loop antenna that is passively coupled to the ferrite rod in the radio to pull in the station, it works well.
But there is a station at 1200KHz on nearly the same vector that bleeds over the station I want.
How can I make a low pass RF filter that would choke off anything above 1190KHz and employ it with my present setup??
