stabistor
Hi Fernando,
You won't find any reference about a BZX55C1V2 because it never existed !
You won't find it either in any other series of voltage regulator diodes
because they all start at 2V4. The only stabistors that might be still
available are the BZV86 and BZV87 series and they come only in 1V4, 2V0,
2V6 and 3V2. You can find the datasheets here:
Much older stabistors, the BZX75 series, had the same voltage ratings.
An other possibility is to connect two BA220 diodes in series to get 1v4.
That's what a stabistor basically is, a series connection of a number of
diodes.
If your application permits, you could use a LM113 to get 1,25volt.
on1aag.
