Register Log in
Multiplication of float/real value in VHDL
arunprasadvr3
Newbie level 3
Hello,
I need to implement this exprestion in VHDL
Answer=((0.21*255)+(0.72*100)+(0.07*90))
Can anybody help me how to multiply the float values and roundoff the final answer
KlausST
Super Moderator
Staff member
your whole expression is just a constant value: 131.85. No need to calculate anything in VHDL.
Klaus
FvM
Super Moderator
Staff member
Bochum, Germany
VHDL can do the calculation for real variables or constants, need to convert the integer constants to real
e.g.
constant answer : real := (0.21*255.0)+(0.72*100.0)+(0.07*90.0);
or
constant answer : integer := to_integer(round((0.21*255.0)+(0.72*100.0)+(0.07*90.0)));
Real variables aren't synthesizable, depending on what you want to achieve, you'll refer to float or fixed point data type.
arunprasadvr3
Newbie level 3
For understanding I have given constant value.
But the real expression is
Answer=((0.21*R)+(0.72*G)+(0.07*B))
R, G, and B are input for the module
Thanks,
Arun
KlausST
Super Moderator
Staff member
now it´s a complete different situation.
Are you sure you need the output as "float"?
I´d avoid it.
Try to use integer or fixed point multiplication.
Klaus
arunprasadvr3
Newbie level 3
I don't need output as float. I need the output as "integer"
Arun
KlausST
Super Moderator
Staff member
integer...
Signed/unsigned? 8bit, 16 bit, 32 bit?
I´m no specialist in VHDL.
Thus here my "hardware style" explanation:
depending on what accuracy you need I recommend to replace it with integer multiplication.
Example:
0.21 x R
expand it by 2^16 = 65536
0.21 * 65536 * R / 65536
now combine:
(0.21 * 65536) * R / 65536
and make this an integer value (or let the compile do the job)
(0.21 x 65536) = 13763
--> 13773 * R / 65536
The hardware just calculates "13773 * R" (integer 16 bit x 16 bit multiplication)
and the "/65536" is just a shift 16 bits to the right. ... which indeed is replaced as "wiring" (it takes bits 0..15 of the result instead of bits 16..31)
Klaus
    V
niciki
Gdańsk, Poland
It looks like you want to convert RGB->grayscale.
You can do this without floating values at all.
Code VHDL - [expand]
8
9
10
11
process(clk_pix)
begin
    if rising_edge(clk_pix) then
        grayPixel <= (x"4c"*redSignal + x"97"*greenSignal + x"1C"*blueSignal); --weighted color
    end if;
end process VideoEdition;
--output video signals
OUT_vid_data(23 downto 16) <= grayPixel(15 downto 8); --red channel
OUT_vid_data(15 downto 8) <= grayPixel(15 downto 8); --green channel
OUT_vid_data(7 downto 0) <= grayPixel(15 downto 8); --blue channel
The source:
http://miscircuitos.com/video-processing-fpga-zybo-using-vhdl/
    V
FvM
Super Moderator
Staff member
Bochum, Germany
I think you are still learning to ask clear questions.
As far as I understand now, you want synthesizable VHDL. In- and output is 8 bit unsigned. The resolution of the fixed point factors need to be still defined, 8 bit could be a first guess. The code can be comfortably implemented using IEEE fixed point library or with elementary numeric_std operations. The latter similar to what KlausST suggested, converted to legal VHDL syntax.
    V
Toggle Sidebar
