multiplication in verilog with value from ROM
siva_7517
Full Member level 2
I am currently doing multiplication with 2 different value of Q which is from ROM.
Below is an example of code of top module :
top (....)
assign tmpMult_1 = $signed(A) * $signed(Q); // Q=0.7071
assign tmpMult2_1 = tmpMult_1 - ($signed(B) * $signed(Q)); // Q= -0.7071
endmodule
I have a ROM verilog code:
module rom (read_en, address, Q);
input read_en;
input [2:0] address;
output [15:0] Q;
reg [15:0] Q;
always@(posdege read_en)
begin
case (address)
1'b0 : Q <= 16'b0101101010000010 // 0.7071
1'b1 : Q <= 16'b1010010101111110 // -0.7070
endcase
endmodule
How can instantiate this code to top module?
thanks in advance
steven852
Maybe you would try to clock the outputs of ROM for different inputs so that you can re-use the ROM module for two Q values at the same time.
magnanimus
Newbie level 3
uttarpradesh
top (....)
endmodule
input read_en;
output [15:0] Q;
reg [15:0] Q;
begin
case (address)
endcase
endmodule
thanks in advance
It's very simple
you'r data type in the rom module is
read_en ---- input wire type
address ---- input wire type
Q ---- output reg type
now to instantiate this module in top module declare
read_en as reg or wire type
address as reg or wire type
Q as wire type
(all the variables with same size)
and instantiate as
rom <module_name>(read_en,address,Q);
*module_name could be any character
