I need to display a 3 digit number using 3 seven segment displays..
For Ex 516
How can I convert the number into hundred digit(Ex: 5), ten digit(Ex : 1), one digit(Ex : 6) using MPLAB assembly coding?
first of all you have to write the 7 segment code and after this you can interface PIC with your display in MUX fashion.
to display the given no you have to continue refreshing the displays
if you want to know more tell me about your project
Added after 4 minutes:
to convert the code use data sheet of 7 seg desplay
