I want to have a SPI flash chip that can do 4-bit IO to be accessible as both a memory mapped device to a soft CPU for reading, and as an SPI device for direct access to all the other commands in it, selectable by a register (fl_mem_enable).
This requires multiplexing of inout signals, and i can't quite figure out how to do it.
The code below mostly works - SPI mode works fully, but the mem mode does not get any data into it.
Apparently assignment like "assign FL_IO =fl_mem_enable?mem_FL_IO:{3'bz,gio_FL_MOSI};" only controls the output and enable parts of inout, but does not pass the input part.
However, trying to add something like "assign mem_FL_IO=FL_IO;" or "assign mem_FL_IO=fl_mem_enable?FL_IO:4'b0000;" gives out errors.
So, what am i doing wrong or how to do it right?
Code Verilog - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
| module top(
//SPI FLASH
output FL_CS,
output FL_SCK,
inout [3:0] FL_IO,
wire mem_FL_CS;
wire mem_FL_SCK;
wire [3:0] mem_FL_IO;
wire gio_FL_CS;
wire gio_FL_SCK;
wire gio_FL_MOSI;
wire fl_mem_enable;
assign FL_CS =fl_mem_enable?mem_FL_CS:gio_FL_CS;
assign FL_SCK=fl_mem_enable?mem_FL_SCK:gio_FL_SCK;
spi_flash mem(
.CS(mem_FL_CS),
.SCK(mem_FL_SCK),
.IO(mem_FL_IO),
gio sysgio(
.FLROM_CS(gio_FL_CS),
.FLROM_SCK(gio_FL_SCK),
.FLROM_MISO(FL_IO[1]),
.FLROM_MOSI(gio_FL_MOSI),
.fl_mem_enable(fl_mem_enable),
