dika
Member level 4
i'm trying to build a multiplexer for sensor detection using 8051 (89s52). this device communicates to a data concentrator which used msp430. i'm using UART to communicate between both mcu.
there's 16 analog sensors thats going to be read and they're approx. 10 meters away from the mcu units. and they're using AC voltage
these sensors only triggered (sends a voltage value) when it's active, so i'm thinking to use relays or some comparators to detect some voltage limit and sends it to the 8051.
the thing is i'm too sure whether the signal from the sensor will be read by the 8051 because of the distance. and whether using relays and comparator is a good idea
and how do i detect if there's a sensor triggering without using interrupts, coz i'dont think there's enough interrupts and polling isn't a good idea (isn't it)
anybody have suggestion or advice or objection?
thanks before
thanks before
