Register Log in
multiplexed 7 segments driven using PIC18F452
furqankaimkhani
Member level 4
I am driving 6 'common anode 7-segments' using my PIC18F452 (using multiplexed technique).
This is working perfectly fine in proteus simulation.
I am driving these directly with the pins of PIC (I have 1 Kilo ohms resistors only on the common anode pins "segment selectors pins").
The problem I am having is that the segments are too dark to be seen in the room light. Can anyone suggest a solution pls.
see this
alexan_e
Administrator
Greece
You need more current and PIC can't provide it.
Use transistors to drive the common pins (or mosfet) and connect the segments through resistors to the pic.
Toggle Sidebar
