tongwe3bw
Newbie level 1
I need some help resolving this issue on PIC18F4520. I am trying to run multiple timer, timer0,timer1 and timer3. Each timer will generate short pulse repeatedly, and the pulse is intend to control the position of the servomotor.
if I program in this way:
#include <p18f4520.h>
#define servo1 PORTBbits.RB0
#define servo2 PORTBbits.RB1
#define servo3 PORTBbits.RB2
#pragma config WDT = OFF // turn off watch dog timer
void init (void);
void InterruptAct();
void OnT0(void);
void OnT1(void);
void OnT3(void);
unsigned char servoCon1,servoCon2,servoCon3;
#pragma code Interrupt = 0x08 //interrupt pointer address 0x18 low priority
void Interrupt(void)
_asm //assembly code starts
goto InterruptAct //interupt control
_endasm //assembly code ends
#pragma code
#pragma interrupt InterruptAct
void InterruptAct()
if(INTCONbits.TMR0IF==1)
if(servoCon1 == 1)
servo1 = 0;
servoCon1 = 0;
TMR0H=0X3C;
TMR0L=0XAF;//20ms
else
servo1 = 1;
servoCon1 = 1;
TMR0H=0XEE;
TMR0L=0X6B;
INTCONbits.TMR0IF=0;
#pragma code main=0x30
void main (void)
init();
OnT0();
OnT1();
OnT3();
while(1)
void init (void)
/* Port setup */
//TRISBbits.TRISB0=0;
//TRISBbits.TRISB7=0;
TRISB = 0x00;
TRISC = 0x00; //declare as output
TRISD = 0x00; //declare as output
servo1 = 1;
/* Timer setup */
//timer0
T0CON=0b00000000;
TMR0H=0X3C;
TMR0L=0XAF;
//timer1
T1CON=0b11010100;
TMR1H=0X3C;
TMR1L=0XAF;
//timer3
T3CON=0b11010100;
TMR3H=0X3C;
TMR3L=0XAF;
//Interrupts
INTCONbits.TMR0IE=1; //Enables the TMR0 overflow interrupt
PIE1bits.TMR1IE=1; //Enables the TMR1 overflow interrupt
PIE2bits.TMR3IE=1; //Enables the TMR3 overflow interrupt
INTCONbits.TMR0IF=0; //TMR0 register clear overflow
PIR1bits.TMR1IF=0; //TMR1 register clear overflow
PIR2bits.TMR3IF=0; //TMR3 register clear overflow
INTCONbits.PEIE=1; //Enables all unmasked peripheral interrupts
INTCONbits.GIE=1; //Enables all unmasked interrupts
void OnT0(void)
T0CONbits.TMR0ON=1;
void OnT1(void)
T1CONbits.TMR1ON=1;
void OnT3(void)
T3CONbits.TMR3ON=1;
This code will generate nice pulse at RB0 output.
But when I try to have 3 timers generate interrupt to generate individual pulse width:
void init (void);
void OnT0(void);
void OnT1(void);
void OnT3(void);
#pragma code
void InterruptAct()
if(servoCon1 == 1)
servo1 = 0;
servoCon1 = 0;
TMR0H=0X3C;
TMR0L=0XAF;//20ms
else
servo1 = 1;
servoCon1 = 1;
TMR0H=0XEE;
TMR0L=0X6B;
if(PIR1bits.TMR1IF==1)
if(servoCon2 == 1)
servo2 = 0;
servoCon2 = 0;
TMR1H=0X3C;
TMR1L=0XAF;//20ms
else
servo2 = 1;
servoCon2 = 1;
TMR1H=0XEE;
TMR1L=0X6B;
PIR1bits.TMR1IF=0;
if(PIR2bits.TMR3IF==1)
if(servoCon3 == 1)
servo3 = 0;
servoCon3 = 0;
TMR3H=0X3C;
TMR3L=0XAF;//20ms
else
servo3 = 1;
servoCon3 = 1;
TMR3H=0XEE;
TMR3L=0X6B;
PIR2bits.TMR3IF=0;
void main (void)
init();
OnT0();
OnT1();
OnT3();
while(1)
void init (void)
/* Port setup */
TRISB = 0x00;
servo1 = 1;
/* Timer setup */
//timer0
T0CON=0b00000000;
TMR0H=0X3C;
TMR0L=0XAF;
//timer1
T1CON=0b11010100;
TMR1H=0X3C;
TMR1L=0XAF;
//timer3
T3CON=0b11010100;
TMR3H=0X3C;
TMR3L=0XAF;
//Interrupts
void OnT0(void)
T0CONbits.TMR0ON=1;
void OnT1(void)
T1CONbits.TMR1ON=1;
void OnT3(void)
T3CONbits.TMR3ON=1;
The interrupts seem to be conflict at one another and only RB2 have pulse output. No pulse at RB0 and RB1.
Appreciate if any help is given.
void init (void);
void OnT0(void);
void OnT1(void);
void OnT3(void);
#pragma code
void InterruptAct()
if(servoCon1 == 1)
servo1 = 0;
servoCon1 = 0;
TMR0H=0X3C;
TMR0L=0XAF;//20ms
else
servo1 = 1;
servoCon1 = 1;
TMR0H=0XEE;
TMR0L=0X6B;
void main (void)
init();
OnT0();
OnT1();
OnT3();
while(1)
void init (void)
/* Port setup */
TRISB = 0x00;
servo1 = 1;
/* Timer setup */
//timer0
T0CON=0b00000000;
TMR0H=0X3C;
TMR0L=0XAF;
//timer1
T1CON=0b11010100;
TMR1H=0X3C;
TMR1L=0XAF;
//timer3
T3CON=0b11010100;
TMR3H=0X3C;
TMR3L=0XAF;
//Interrupts
void OnT0(void)
T0CONbits.TMR0ON=1;
void OnT1(void)
T1CONbits.TMR1ON=1;
void OnT3(void)
T3CONbits.TMR3ON=1;
void init (void);
void OnT0(void);
void OnT1(void);
void OnT3(void);
#pragma code
void InterruptAct()
if(servoCon1 == 1)
servo1 = 0;
servoCon1 = 0;
TMR0H=0X3C;
TMR0L=0XAF;//20ms
else
servo1 = 1;
servoCon1 = 1;
TMR0H=0XEE;
TMR0L=0X6B;
if(servoCon2 == 1)
servo2 = 0;
servoCon2 = 0;
TMR1H=0X3C;
TMR1L=0XAF;//20ms
else
servo2 = 1;
servoCon2 = 1;
TMR1H=0XEE;
TMR1L=0X6B;
PIR1bits.TMR1IF=0;
if(servoCon3 == 1)
servo3 = 0;
servoCon3 = 0;
TMR3H=0X3C;
TMR3L=0XAF;//20ms
else
servo3 = 1;
servoCon3 = 1;
TMR3H=0XEE;
TMR3L=0X6B;
PIR2bits.TMR3IF=0;
void main (void)
init();
OnT0();
OnT1();
OnT3();
while(1)
void init (void)
/* Port setup */
TRISB = 0x00;
servo1 = 1;
/* Timer setup */
//timer0
T0CON=0b00000000;
TMR0H=0X3C;
TMR0L=0XAF;
//timer1
T1CON=0b11010100;
TMR1H=0X3C;
TMR1L=0XAF;
//timer3
T3CON=0b11010100;
TMR3H=0X3C;
TMR3L=0XAF;
//Interrupts
void OnT0(void)
T0CONbits.TMR0ON=1;
void OnT1(void)
T1CONbits.TMR1ON=1;
void OnT3(void)
T3CONbits.TMR3ON=1;
