streetHawkk
Newbie level 5
- Joined
- May 14, 2012
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,359
Hi Friends,
Please guide me if my approach is not correct. Basically i have requirement where i need to use a MUX to access a shared memory from 4 different modules.
I have a multiplexer module with four possible selections as shown below.
MUX_AD
S1:S0 = "00", "01", "10" & "11"
I have 4 components say A, B, C & D which requires to use this mux to access this memory.
Can i instantiate the MUX_AD in each of these different components and connect accordingly. Will this work.
Component A : selects S1:S0 = "00"
Component B : selects S1:S0 = "01"
Component C : selects S1:S0 = "10"
Component D : selects S1:S0 = "11"
Similary for other 2 components C & D from separate vhdl files.
Thanks
Hwk
MUX_AD
Code VHDL - [expand] 1 2 3 4 5 6 7 entity MUX_AD is ( * addra : IN std_logic_vector(4 downto 0); * douta : OUT std_logic_vector(7 downto 0); * sel : IN std_logic_vector(1 downto 0) ); end entity;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ======================== Component A (compA.vhdl) ----------- signal compA_addra : std_logic_vector(4 downto 0); signal compA_douta : std_logic_vector(7 downto 0); signal compA_sel: std_logic_vector(1 downto 0); Port mapping ------ ap : MUX_AD PORT MAP( addra => compA_addra, douta => compA_douta, sel => compA_sel ) ======================== Component B (compB.vhdl) ----------- signal compB_addra : std_logic_vector(4 downto 0); signal compB_douta : std_logic_vector(7 downto 0); signal compB_sel: std_logic_vector(1 downto 0); Port mapping ------ ap : MUX_AD PORT MAP( addra => compB_addra, douta => compB_douta, sel => compB_sel )
Thanks
Hwk
