multiple clocks in the design
For multiple application, I means a standby clock which run around kHz, a system clock with wide range in MHz...
A real time clock with a crystal at 32678Hz.
Application Specfic.
Simple Example:
If you want to Ring a Bell at 1hr Interval , You will use at some freq(Say 10M Hz).
And If you want to Ring the bell at 8hr interval, You will require one more freq(Say 10K Hz).
