multiple clock divider
triump.ar
Junior Member level 2
hi,
i have to design a clock divider ckt which will divide the input clock of 64 mhz by multiple clock
1 is divide by 8 then second divide by 16 then divide by 32...
how to do it in a single program...
cherjier
Member level 5
if you are using an FPGA, and DCM/PLL will do the clock dividing.
if you just wan the clock to be divided, the most direct method is using a counter.
i have write you a simple code for the divider..
module clk_divider (
	clk_in,
	reset_n,
	clk_div8,
	clk_div16,
	clk_div32
input clk_in;
input reset_n;
output clk_div8;
output clk_div16;
output clk_div32;
//register output
//assign	clk_div8 = counter[2];
//assign	clk_div16 = counter[3];
//assign	clk_div32 = counter[4];
// only for xilinx
BUFG	BUFG_U0 ( .I(counter[2], .O(clk_div8));
BUFG	BUFG_U1 ( .I(counter[3], .O(clk_div16));
BUFG	BUFG_U2 ( .I(counter[4], .O(clk_div32));
reg	[4:0] counter;
always @(posedge clk_in or negedge reset_n)
	if (!reset_n)
		counter <= 5'b00000;
	else
		counter <= counter + 1;
endmodule
triump.ar
hey, i want to do it in vhdl...
cherjier
Member level 5
than u just rewrite the code in vhdl..that's all
the architecture are the same...
used a 5bits counter from 00000 to 11111 than repeat... u will get all the div value that you wan. bit 2 is div 8, bit3 is div16 and bit4 is div32 and you are done
    triump.ar
kvingle
Full Member level 5
India.
-- KeyShore
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity clk_gen is
  port (
    system_reset : in  std_logic;       --  reset
    clk_in       : in  std_logic;       --  clk in
    clk_div8     : out std_logic;
    clk_div16    : out std_logic;
    clk_div32    : out std_logic
end clk_gen;
architecture clk_gen_a of clk_gen is
  signal count1 : std_logic_vector(4 downto 0);
begin  -- clk_gen_a of clk_gen
  process(clk_in, system_reset)  -- proc to gen  clk_div8 counter
  begin
    if system_reset = '0' then
      count1 <= (others => '0');
    elsif rising_edge(clk_in) then
      count1 <= count1 +1;
    end if;
  end process;
  clk_div8  <= count1(2);
  clk_div16 <= count1(3);
  clk_div32 <= count1(4);
end clk_gen_a;
use bufg primitives for outputs if you are using a xilinx device.
