Multicycle Hold analysis
kumar_eee
Advanced Member level 3
Bangalore,India
Can anyone tell me about multicycle hold analysis? Does it affect the frequency of the chip?
Hi Kumar,
By default hold check is done once clock edge prior to the setup check. So same holds for Multi cycle path..If u want the check to be performed on the same edge as the launch we need to specify to the tool using a command...
cheers
multi cycle hold is done by specifications of the designer when you are sure that the path takes more than 1 cycle.You can specify the edge for setup and hold checks
And speaking about frequency...Multi cycle path is specified when your logic is working slower than the base clock frequency............correct me if I'm wrong
agree what the said of jeevan.life.
we do MCP analsysi for setup time, hold will change due to setup edge change.
