Multi-output Power Supply
kieennx
Junior Member level 3
power supply schematics multiple outputs
Hi all,
I need to use a multi-output power supply at the moment. Its main specifications are listed below:
- Input range: 100 - 370 VDC
- Outputs:
+5VDC@2A
+12VDC@1A
-12VDC@0.5A
+24VDC@2A
Is there any circuit/IC to design it or is there any module that sold on market?
Please give links if possible.
Thanks alot.
kieennx.
rapid design circuits from national semicond
Quad output supplies are quite common. Here is one source
atx power supply lab
h**p://www.meanwell.com/search/DataWebForm1.aspx
HI
the link doesn't work
please resend the correct one
thanks alot
Ahmed
www.i-g.org
multi output lab power supply circuits
As usual there are several options ..
- off-the-shelf product - hundreds of them available - example(s): have a look at: **broken link removed**
- budgetary .. "By converting the cheap (free) ATX power supplies that can be found in any discarded computer, you can get a phenomenal lab power supply with huge current outputs, short circuit protection, and very tight voltage regulation.
Here are details:
http://wiki.ehow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
- and so on ..
Regards,
IanP
power supply outputs
the more economic is buying a computer one.
If you wanto to design one there are several options
recomendations
SG3524 texas Instr, National semicond, fairchild semicond
TL594 de texas instruments
and the rapid design circuits from National Semicond
